Podařilo se mi nainstalovat CH IMPortal, což je vlastně IM portál upravenej pro CH Mod.
Umožní vložit na stránku bloky, do kterých se automaticky posílají příspěvky atd. z fóra.
Mód se dá stáhnout na stránkách CHMods Demoboard.
Češtinu můžete najít tady.
## MOD Title: CH IMPortal
## MOD Author: Craterz < n/a > (n/a) http://www.craterz.com/
## MOD Updated by: Haynes <haynes@chmods.de (N/A) http://chmods.de
## MOD Description: This MOD is a CH 2.1.6h adapted version of IMPortal.
## phpBB IMPortal by: masterdavid
## < webmaster@integramod.com > (Ronald John David) http://www.integramod.com/
## MOD Version: 1.0.8a
## Installation Level: Easy
## Installation Time: 25 minutes
## Files To Edit: admin/index.php
## includes/class_config.php
## includes/class_stats_online.php
## includes/im_portal/class_im_portal.php
## login.php
## templates/ptifo/admin/index_navigate.tpl
## templates/ptifo/overall_footer.tpl
## templates/ptifo/overall_header.tpl
## templates/ptifo/ptifo.cfg
## templates/ptifo/ptifo.css
## templates/subSilver/admin/index_navigate.tpl
## templates/subSilver/overall_footer.tpl
## templates/subSilver/overall_header.tpl
## templates/subSilver/subSilver.cfg
## templates/subSilver/subSilver.css
## Included Files: root/*.*
## Author Notes:
## Based on/with IMPortal 1.2.0 EMC Beta by masterdavid
## Requires CH 2.1.6e
## Always backup your files and database prior to installing any MOD.
## You DO NOT need the original IMPortal MOD, this includes everything you need.
## Be sure to visit the caches management in the ACP and 'Regen' the Lang cache when complete.
## This following is shamelessly borrowed from Smartor's ezPortal installation instructions.
## HOW TO MAKE YOUR WEBSITE OPEN TO FILE portal.php INSTEAD OF index.php ?
## Do NOT do this until this MOD is successfully installed!
## You can use one of the following methods! Lots of luck!
## o Method 1: (for Apache server)
## Create/modify file .htaccess in phpBB root directory add/edit this line:
## DirectoryIndex index.html index.htm portal.php index.php
## o Method 2: {use META tag - if you cannot apply the 1st method)
## Create file index.html in phpBB root directory (without #)
## <html>
## <head>
## <title>Redirecting...</title>
## <meta http-equiv="refresh" content="0;url=portal.php">
## </head>
## <body>
## </body>
## </html>
## If your phpBB was placed in a subdirectory to the webroot, like: http://www.something.com/forum you could create index.html in the webroot and modify the line 4 to <meta http-equiv="refresh" content="0;url=forum/portal.php">
## o Method 3: I think maybe you can find out method 3 yourself ;) like JavaScript, etc.
## MOD History:
## 2008-08-26 - Version 1.0.8a
## -fixed several bugs and missing lang keys
## -moved towards the CH plugin system
## 2007-10-12 - Version 1.0.8
## -Updated for CH 2.1.6e compliance
## -Added ability to control scroll within Recent Topic block
## -Removed number of posts (x) unread from User Block, cannot determine number
## on all pages where User Block may be shown (if set in Global Header)
## May return in future version, but currently is unstable.
## 2006-07-30 - Version 1.0.7
## -Changed a few things for forum and user blocks, for better/easier tpl editing
## fetchposts.php
## blocks/blocks_imp_forum.php
## blocks/blocks_imp_user_block.php
## language/lang_english/lang_extend_CH_IMPortal.php
## templates/ptifo/blocks/forum_block.tpl
## templates/ptifo/blocks/user_block_block.tpl
## templates/subSilver/blocks/forum_block.tpl
## templates/subSilver/blocks/user_block_block.tpl
## -Redifined a CH language variable for better wording
## -NOTE: To update, just upload and replace the following files:
## 2006-07-30 - Version 1.0.6
## -Fixed an issue with group names not properly showing up in ACP pages
## admin/admin_portal_blocks.php
## admin/admin_portal_layout.php
## 2006-07-30 - Version 1.0.5
## -Fixed a javascript error on portal/home page
## -Fixed a javascript error on all other pages
## 2006-09-03 - Version 1.0.4
## -Fixed a number of language vars not being filled properly.
## instead of entire site name.
## There are no db changes (except one... it's minor and not needed to update).
## If you've modded the files, make use of WinMerge or some such.
## -Fixed a few other minor HTML coding issues.
## -Fixed an issue with the statistics block not showing up after install.
## -Added a language var so that on Nav block it only shows 'Forum Index'
## -NOTE: To update, just remove the old files from your site and upload new ones.
## 2006-07-30 - Version 1.0.3
## -Moved db_update.php to root folder.
## -Changed Recent Topic block start scroll delay time to 5 seconds.
## 2006-07-30 - Version 1.0.2
## -Fixed a couple things causing easyMOD to fail.
## -Added note to regen lang cache.
## 2006-07-10 - Version 1.0.1
## -Fixed a SQL issue in db_update.php and sql.txt
## -Fixed a confusing point in installation instructions (this).
## 2006-07-04 - Version 1.0.0
## -Released to Registered users at my board.
## 2006-07-02 - Version 0.0.4
## -Added template instructions for ptifo.
## -Added a missed instruction.
## 2006-06-30 - Version 0.0.3
## -Fixed the major problem.
## -Fixed several minor issues with titles and such not displaying.
## 2006-06-29 - Version 0.0.2
## -Made most necessary changes.
## -Completely rewrote installation instructions (this).
## -Renamed SQL inserted tables for better organization.
## -Created an semi-automated SQL installer.
## -Navigation block is now truely global.
## -Includes ACP set Navigation icon.
## -Rewrote several/many files to make use of CH aspects.
## -Rewrote scrolling mechanism of Recent Topics block.
## -Scrolling is now XHTML compliant.
## -Fixed when recent topic is by a Guest.
## -Fixed many (X)HTML compliance issues.
## -Still tracking one major problem.
## 2006-06-27 - Version 0.0.1
## -Began developing adaption.
1. Pro Apache servery - Vytvořte/změňte soubor .htaccess ve vašem fóru tak, že do něho vložíte nebo upravíte tento řádek:
2. Vytvořte soubor index.html, který vložíte do vašeho kořenového adresáře fóra a do něj tohle:
<html>
<head>
</head>
<body>
</body>
</html>
